ABS / Brake Light Activation
I own a 2001 GMC Yukon XL and until now have been happy with it. I am experiencing ABS / Brake light activation intermittently. If I turn the ignition off and turn it on again, the lights will disappear. Sometimes, the light(s) will not come on in days. Sometimes they will come on five days in row. I would appreciate some insight on this problem. Thank You!
Re: ABS / Brake Light Activation
Checked t\your fluid levels? Changed brakes recently? Is the ABS unit humming constantly?
The brake reservoir is full. The abs motor comes on for a few seconds at start up and then stops. I replaced the brakes (front & rear) approximately six months ago. I also removed the front wheels and cleaned the speed sensors. I did not check the resistance of the sensors. Would the sensors cause both the ABS and brake light to come on concurrently??
Usually its only worn out brake. I am probably out of my league if I add anymore than I have because I have not had this happen. Anyone else?
WSS could cause the light to come on..best thing to do is get the codes read.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
I am having the same "issues" with my wife's 01 yukon and the dealer says the codes indicate that I need a $1800 ABS module. Is this what you did to fix the problem???
or http://www.modulemaster.com/ //2000CAYukon |
The ground should be on the frame rail just beneath the driver's side door. |
Removed the ground. Cleaned off the ton of rustproofing and road crap with steel wool and simply green. ABS is working great so far. The ground is actually on a extention of the frame rail that attaches to the body with the rubber boots. You won't have any problem finding it. Thanks very much for the post saved me at the very least 800 dollars.
I also have a 2001 Yukon,and am having the same problems.Both ABS and brake lights are coming on at the same time,but not every day.But recently has gotten worse,and has stayed on for 3 days every time we used the vehicle.I am going to try the repair to the ground and will post the results after a few days of trial.Thank you for posting this information,Im sure it will help alot of folks like me.
Welcome to AF. Very old thread here, if any new info please start a new one.
