Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 10-08-2005, 09:30 PM
stone_mound_camaro's Avatar
stone_mound_camaro stone_mound_camaro is offline
stallin car
Hey I'm a lil new to intrepids. I just got mine the other day and at idle, the oil pressure light comes on and then the engine stalls? Car has 87k on it. Wuts the deal??
car audio guru...
Old 10-11-2005, 01:58 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: stallin car
is it making any unusual sounds while it's acting up?
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-12-2005, 12:54 AM
Re: Re: stallin car
Well... silence. J/k but real talk, it makes no noises. I also noticed that it will only shut off when the steering wheel turns and i am below 5 mph usually happens whilst turning left, but i have yet to try a right turn.
car audio guru...
Old 10-12-2005, 02:10 PM
Re: stallin car
if your check engine light is on, it might be your power steering pressure sensor that's acting up. The sensor jacks up the idle during parking lot procedures when P.S. pressures are high so that your motor won't stall.
Old 10-12-2005, 03:49 PM
Re: stallin car
As a matter of fact, I think you hit that right on the head, my check engine light is on because of a fault power steering sensor. But can you tell me what that has to do with the idle again; I didn't really comprehend your last sentence.
car audio guru...
Old 10-12-2005, 09:30 PM
Re: stallin car
When you are about to turn into a parking spot, your engine is at idle. As soon as the steering wheel is turned, your power steering pump generates the most pressure when you initially turn the wheel. As a result, that power steering pressure sensor increases the idle speed so that the engine does not stall out during parking procedures.
Old 10-12-2005, 09:46 PM
Re: stallin car
Ok thanks
car audio guru...
