i have a rebuilt ct26 from a 89 supra and want to install on a stock 22re,(parts aquired so far )-ct26 turbo,modified 86 turbo manifold,inercooler,some home made oil lines & water lines and thats all ,any help from where to start . price is a problem so any swaps or mods would nice.....what fuel management should i use if any? |
Just a few things.
You'll need higher cfm injectors You'll need to drill and tap the block for the turbo's oil lines. You'll need either the Ceilicas ECM and wiring harness or an aftermarket system. You'll need a bigger radiator. Since the 22RE has a higher compression, and uses weaker pistons than the 22RTE, you'll have to keep the boost low to avoid destroying the engine.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
