Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 10-08-2005, 07:58 PM
CTD20 CTD20 is offline
US spec 3S-GTE
Anyone know where I can get a U.S. spec 3S-GTE, preferably with all the bits for a turbo swap? I realize the j-spec engines are more powerful and better performers (in most cases anyway), but this is going to be a daily driver and I don't need any unnecessary hassles. Any info would be spiffy.
I'm not looking to be anyone's hero, I just want to enjoy my car.
Old 10-08-2005, 11:09 PM
Different approach
Had a thought, can the JDM motors be retrofitted to pass Calif. smog? Maybe throw on the U.S. manifolds, sensors and use a U.S. ECU? Any ideas people?
Old 10-10-2005, 06:19 AM
bob stone's Avatar
bob stone bob stone is offline
Re: US spec 3S-GTE
you live in ca ??
got a blow engine or something, ?? umm maby a junk yard with a mr2 with the front bashed in or something like that ?
but my 2 cents, stick with a usdm engine, mush less hassle
I got someone here in japan offering me a complete mr2 that was in a crash which damaged the front only for 1k? so I guess ya can search around for something like that in CA
Some folk have IQs
Which force them to choose
The most complicated solution in view.
But those smarter yet
Will never forget
That the simplest answer is usually most true.
Old 10-10-2005, 01:29 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: US spec 3S-GTE
http://www.paautoracing.com/ sells full clips.
I would not advise getting JDM.
The USDM is better under almost all circumstances IMO.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 10-13-2005, 09:22 PM
arber arber is offline
Re: US spec 3S-GTE
get a jdm engine use stock wiring and stock comp and u will be very happy.it will run really good and clean. there is a lot of ways to pas emmissions. jdm engine runs clean at 2500 rpm that is the rev that they test the smoke. you can get a jdm engine with trany shipped to your home for 2000 $ its a bargen.but i will take my car and tested in MA for emmissions same as the one in CA and i will get back to you
Old 10-16-2005, 01:55 PM
Thanks Hyde.
Old 10-16-2005, 02:07 PM
New question
Anything special I need to know about the turbo swap? Fabrication? Harnesses and connectors match up? Need to change the fuel lines? Pump? Radiator? Fans? Anyone got a swap report? Thanks all.
