Old 10-08-2005, 07:24 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Question Ls1 "knock"?
Hi, i have a 2000 pontiac trans am. And i know u have to run preimum gas in it. But it has 33,000 on it and i just got it like 2 weeks ago. And i use premuim gas, but i do not know who owned it befor me and what gas they ran in it. So when i frist start it it semms to have a little ping or like a knock. Will this go away after a while?
Old 10-08-2005, 07:43 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Ls1 "knock"?
Does it go away once it is warmed up?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 10-08-2005, 07:54 PM
97cavalier's Avatar
Re: Re: Ls1
Ya it goes away but if you rev it up it does it a little. When you rev it up tho it almost sounds like that noise is comming from the muffler. But when you frist start it, it almost sounds like a deisel. ha ha. not that loude but it is that kinda ping. i heard of this befor when people run regular in them and you run premuium for a while and it will go away.
Old 10-08-2005, 07:59 PM
Mr. Luos's Avatar
Firebird Guy
Re: Ls1 "knock"?
If you run regular in it, you shouldn't own it. GM doesn't recommend premium, they require it.
The cold start knock is probably 'piston slap' which is something GM has deemed normal on the cars. Has something to do with the pistons coating material.
I would keep running premium in her and see how that works out.
Stock'ish'
Old 10-08-2005, 08:10 PM
97cavalier's Avatar
Re: Re: Ls1
I did NOT run regular in it i am not that dumb. I THINK the person befor me did that is why i asked that.
Old 10-08-2005, 09:08 PM
Mr. Luos's Avatar
Firebird Guy
Re: Ls1 "knock"?
Sorry, I wasn't refering to you in particular. Just anyone that might do it.
Stock'ish'
Old 10-09-2005, 09:42 AM
CreepingDeath94 CreepingDeath94 is offline
Did GM require premium in the LT1s as well?
Old 10-09-2005, 09:50 AM
Mr. Luos's Avatar
Firebird Guy
Re: Ls1 "knock"?
I believe so. Although I am not 100% on that.
Stock'ish'
Old 10-09-2005, 11:12 AM
97cavalier's Avatar
Re: Re: Ls1
My brother has the LT1 and it does not require it but will not run as well.slower throttel respnse and that stuff. So i would not run regular in it.
Old 10-16-2005, 06:07 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: Ls1 "knock"?
how about my old 5.7? on the 3g.s it says "premium" but... i ran reg. in it before. it makes popping noises at the muffler :o
Old 10-16-2005, 03:27 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Ls1 "knock"?
If you look in your owners manual, you will see that LT1's were not required to use premium. Due to the reverse cooling they could run higher compressions without the need for high octane fuel but I recommend using premium anyway and I always have used it .
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-17-2005, 06:27 AM
ladybird ladybird is offline
The answer to the question
Ls1's have a #1 cylinder wristpin problem. It causes them to almost sound like a deisel on some days. Its an extremely common problem on that engine. Its not to big a deal.
