Old 10-08-2005, 06:17 PM
eniram59 eniram59 is offline
1997 fule pump
Truck recently would not start - cranked fine but would not run. Did not hear fuel pump cycle. Waited a few minutes and truck sarted. Drove to town and same thing happened again except it didn't start at all.
Removed fuel pump from tank. Connected fuel pump to fuel pump harness and pump cycled as it should. Waited 30 minutes and pump is dead again.
Fuse OK - not sure about relay.
Any ideas?
Old 10-09-2005, 06:44 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Look into the relay, as well as any grounds... Should those be ok, it's most likely your ignition switch..
Old 10-11-2005, 09:46 AM
spivey-1 spivey-1 is offline
fuel pump
Hey man, check your grounds i payed 300 hundred bucks for a new one on my 97 s-10 and it was just a ground wire that was coming loose. The ground wire that was loose on mine was on the driver's side very back of frame. just follow the wires from the fuel pump. but yeah my truck did the same thing run alright for a little while then quit, check the ground
Old 10-12-2005, 05:02 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: 1997 fule pump
The ground wires are back where the bumper bolts on.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
