Old 10-08-2005, 03:37 PM
deagle50ae deagle50ae is offline
New bulbs (foglights on 1st gen 3kgt?)
I just got new silverstar headlights for my 1st gen VR4 and they rock. now i want silverstar's for the fogs... but what the heck is the fog light part number? i've been to 4 places. (walmart, checker, red rooster, and advanced auto) and none of them have a fog light listed. what part number do i need for the fog light on a '93 3k?
-Josh
EDIT
I was just down looking at it all and i cant figure out how to get the damn things off/out. I took off the 4 clips and the cover does not pull off. do i have to take the one screw located above the light fixture out as well? (i am thinking it's an adjustment screw)i dont have any of my tools handy so i can't dig in too deep. anybody done this before that can give me advice? thanks.
Old 10-08-2005, 06:40 PM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
Re: New bulbs (foglights on 1st gen 3kgt?)
The fog lights are sealed beams and as you can tell they have their special little shape so the automaticly make them a dealer product.
and for geting them off im am still trying to figure that out. (i just now got mine lol).
Upgrades... To many to list...
Old 10-09-2005, 12:18 AM
AutostradaVR4 AutostradaVR4 is offline
i dont know what trim level you have, but on my vr4 i had to remove the air dam and pull the bulb from the rear. 5 or 6 bolts and the dam drops. Just unhook the clip and the bulb pulls out. Should be a wall-mart part. 10 minute job. That help you at all?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-09-2005, 12:26 AM
Also, forgot to mention, after you unhook the clip, the bulb doesnt come out of its little metal holder. if you follow up the wire a few inches, youll feel a quick-connect type connection. Just pull it apart. The bulb is sold as that complete unit (bulb with like 3 inches of wire). i got mine at Advance for like $5.
Formerly BlinkRA182
Old 10-09-2005, 02:43 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: New bulbs (foglights on 1st gen 3kgt?)
Originally Posted by 92VR4Red
The fog lights are sealed beams ...
NO, the foglights are NOT a sealed beam. the headlights on a 1st gen are sealed beam...that is the actual bulb is fused together with the bulb housing. for the foglights, the bulbs can acutally be removed from the foglight housing.
simply just remove 3 bolts holding the foglight to the bracket, then disconnect the electrical connection. (this is for the NA, for the TT, i think you have to remove the front air dam, as BlinkRA said.) once the foglight is out, twist the black plastic fixture on the back, and it will come off, revealing the back of the bulb assembly. unhook the metal spring and the bulb will come right out. NOTE: the bulb is attached via wire to the Positive wire lead in the foglight housing. You will need to disconnect the metal connection (male/female) before the bulb+wire is completely disconnected from the housing.
as BlinkRA said, the foglight bulb comes with a wire attached to it. do not try to remove the wire from the bulb, as its suppose to be there. rather, go down the wire and you will see where the wire is attached to another wire. disconnect the wires at that point.
the foglight bulb is an H3 type bulb. they're found everywhere. As BlinkRA said, you can pick one up at your local auto parts store for under 5 bucks.
i've taken my fogs apart and put new bulbs in. i have them out again to puy hyperwhite bulbs in to match the headlights. (i did the H4 headlight conversion, so i can change out the headlight bulbs). once you have the fogs out, this would be a good time to make the wire connections male/female quick disconnect...instead of having to solder the connection all the time or even just mash metal together with pliers.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-09-2005, 06:44 PM
perfect guys. exactly what i needed for info. too bad i'm going to have t go get my tools from the rents place next weekend before i can do it.
Old 10-09-2005, 10:31 PM
Linebckr49's Avatar
tools? borrow these from a friend:
3/8 ratchet
~6" extension
10mm socket
needle nose pliers (maybe) [regular pliers would be fine]
--if the friend has no ratchet&socket, then find a 10mm wrench. if no wrench, then perhaps you could do it with pliers (vise grip pliers would be nice).
there's always more than one way to skin a cat. so if you're just itching to do this, the above tools should get you through it.
93 3000GT base
Old 10-09-2005, 10:51 PM
I even managed to do mine without pliers...jabbed a hole in my finger on the spring clip, but its all good...
Formerly BlinkRA182
Old 10-10-2005, 12:46 AM
I'm thinkin i will steal some tools temporatily from work and do it tomorrow. thanks again
Old 10-10-2005, 10:04 PM
92VR4Red's Avatar
Your thread got my wanting to fix mine... and yep it was just little hallogens. took off front venture plate and took out fog lights got me a H7 bulb and hook those suckers up... and they look good.
Old 10-11-2005, 12:35 AM
H7 bulbs? i thought they were H3?
Old 10-11-2005, 12:39 AM
92VR4Red's Avatar
Yeah the H3 are the reg bulbs they make a H7 type bulb that will fit also and is much brighter.
Old 10-11-2005, 05:22 PM
Linebckr49's Avatar
how much did the H7 bulb cost? very interested...
93 3000GT base
Old 10-11-2005, 06:24 PM
and how high is the wattage rating? I heard that 1st gen fog lamp housing melts with anything over 55 watts
