Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-08-2005, 03:12 PM
golk75 golk75 is offline
94 Boneville Problems
Hello all.
I recently replaced the head gasket and had the heads machined and new valves and seals put in, now the car stars but it pops and makes other weird sounds also the exaust seems to be getting red hot, as well as there is a smell of gas in the oil.
Does the head needs to be brouhg to TDC?
Any sugestions..?
Thanks.
Old 10-08-2005, 03:36 PM
maxwedge maxwedge is offline
A990 racer
Question Re: 94 Boneville Problems
sounds like a misfire, who did this work?, check for the wires being crossed or not properly connected to the plugs, very vague descriptioon of the history/problem. You need on the spot help here if you are not familiar with diagnosing this type problem. any check engine lites, all the injectors reconnected securely and in proper sequence?
Old 10-08-2005, 03:41 PM
Juiced383's Avatar
Juiced383 Juiced383 is offline
It sounds like the camshaft timing is off. I would place the motor @ TDC and check where the cam sprocket(s) are. Keep in mind that if it appears to be WAY off, turn the crank another full because it could be on the wrong stroke. But make sure that the cam(s) line up the way they are supposed to with the crankshaft @ TDC.
Old 10-08-2005, 03:51 PM
The car over heated once and blew the gasket, thats why i replaced it, i had a machine shop do the resurface and the valve job, but when i installed it i had to tork the rocker bolts.
Its a 3800 V6 there is no cam sprocket, does any one have the firing order?.
Thanks alot for all your replys.
Old 10-08-2005, 04:16 PM
Juiced383's Avatar
Oh sorry, I guess I wasn't paying attention, I was thinking it was an OHC motor. Check the ignition timing.
Sorry, I don't have the firing order here at my house.
Old 10-08-2005, 05:33 PM
A990 racer
Should be 165432, but you need to know where they are on the coil pak. Looking at the coil pak from front, l/s coil is 6/3, middle 2/5, r/s 4/1
Old 10-08-2005, 06:08 PM
I got it runnin, the firing order was wrong.
Thank you all for the help.
Old 10-08-2005, 06:17 PM
markwb's Avatar
markwb markwb is offline
Good deal, that has to be a huge relief. Happy motoring!
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
