Go Back   Automotive Forums Car Chat > Mazda > MX-3
Old 10-08-2005, 02:27 PM
chatham chatham is offline
95 MX-3 Engine Swap (Ford Probe)
Okay, I'm looking at a car that is for sale. It's a 1995 MX-3 GS 6CYL. The guy says that the valve seals are gone in the motor that's in it, but he will include a second engine from 97 Ford Probe GT (2.5L). He says that the engine will go in as a clean swap.
Is this true? Will I have any complications if I try to do this? Do you recomend I work on getting the valve seals fixed, or attempt the swap?
Thanks in advance.
Old 10-08-2005, 04:57 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: 95 MX-3 Engine Swap (Ford Probe)
as far as i know the engine/transmission are the same for the ford and the mazda (ford owns mazda) so yea, i think it would work. but if you dont have the knowledge/experience of engine swaps it'd be worth having someone else do it, but work out the cost for the car an the work if you cant do it yourself.
Seatbelts Saved My Life
Old 10-09-2005, 11:08 AM
babybluemx3's Avatar
babybluemx3 babybluemx3 is offline
it's a direct swap...probably the easiest swap the exists
mx-3 fully built klze turbo on 20psi
cardomain pics
Old 10-11-2005, 02:51 PM
mx3man's Avatar
mx3man mx3man is offline
Send a message via MSN to mx3man
do it yourself, just read up the http://www.mx-3.com forums and you'll find boat loads of info.
If you can change oil and name the major components of an engine, then you'll have no difficulty doing this swap.
I've done the swap twice myself and honestly had never change oil myself before I started. lol Easy stuff
Old 01-07-2008, 05:54 PM
Droopers Droopers is offline
would you sell your distributor for the 1.8l v6 if you do the swap
Old 02-02-2008, 02:58 AM
MazdaX's Avatar
MazdaX MazdaX is offline
Thread is two years old almost...
It's the internal coil circuit inside the distributor. When it heats up it ends up causing a short. Simple fix is the HEI conversion and external coil.
http://www.clubprotege.com/wil/howto/hei/index.htm - better than a new or used distributor.
2004 Mazda 6i
1997 Tahoe
