Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-08-2005, 11:44 AM
cesart95 cesart95 is offline
Question check engine light with codes p1507 & o0455
the guy at autozone told me that p1507 was idle air control under speed error and that p0455 was pcm large leak in evaporative emmision control system. Could anybody direct me into how to fix the problem.
Old 10-09-2005, 04:05 PM
exploded99 exploded99 is offline
Re: check engine light with codes p1507 & o0455
The large leak probably means you pulled the gas cap off while the engine was running. This code should clear itself after a few days if that is what happened.
Idle air control valves control your idle, and are a frequent explorer problem. You can remove it and clean it with throttle body cleaner or replace it ( about $50) yourself - its easy to do. Search the web or this site for instructions on cleaning.
