Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 10-08-2005, 10:03 AM
/M3 /M3 is offline
Need Help Locating Fuse for Window
On my 95 Avalon I Noticed that rear 2 windows fail to operate. I wanted to check the fuse before I make the assumption the motors are bad. I can not for the life of me locate the correct fuse. I checked under the dash and did not see it, and did not see it in the engine compartment either. I checked my haynes manual and It seems like it refers to a power m fuse under the dash but I do not see that fuse. any help appreciated.
Old 10-09-2005, 07:08 PM
csaxon csaxon is offline
Re: Need Help Locating Fuse for Window
Did you accidently push in the child protection button on the main window control panel? That prevents the rear windows from operating.
It worked fine until I fixed it!
Old 10-09-2005, 07:16 PM
/M3 /M3 is offline
No the button is not on. I am going to have to remove the door panel I think and check to make sure that the wiring is connected fine.
Old 01-06-2008, 05:51 PM
Phagger Phagger is offline
Wink Re: Need Help Locating Fuse for Window
Your rear windows are probably just stuck shut. It happened to me 96 on both rear windows cuz the previous owners never used them. just give them a good smack or pry up the window weather stripping. over time the weather stripping seems to melt to the window. I had to clean the tops of the windows real good cuz they got stuck a couple more times before I got them clean enough. Notice how they never quit working when the window is down?
