pulls right on accel after repair
hi
i have a 01 intrigue gls with pcs system,after getting my car back from the dealer it pulls right on accel,the harder the accel the harder the pull they installed a rebuilt rack n pinion,front hub bearings (both sides) when problem started.took it back and they put in 4 new motor mounts and another rack,still same problem.the alignment was checked and is within spec also has 4 new goodyear eagle tires.its got 60,000 miles.original complaint was a groaning in the steering (still there) and a loud roaring from the front end all road speeds,louder on turns (still there).also does the optional trans have limited slip? any ideas |
Re: pulls right on accel after repair
see if an area in the front is starting to heat up. Maybe a brake rotor, bearing etc. With all that drag something must be getting hot. Compare the one side with the other.
