Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-08-2005, 03:28 AM
Eric67 Eric67 is offline
Stalling 95 Jimmy
I just purchased a 95 Jimmy SLS 4door 4WD with 174,000 miles. It runs well for the most part, but once it gets under 1/2 tank of gas, it stalls occasionally under braking or turning. I had the EGR code, and replaced it. Now I have a 441 code "Purge flow fault". I replaced the gas cap, cleaned what I could of the intake without removing it and added gas treatment and fuel injection cleaner.
The guy I bought it from said he put a new fuel pump in it, but it occasionally stalled when under 1/4 of a tank, even before replacing the pump. I was thinking there may be a crack in the line between the pick-up and fuel pump. Any ideas would be appreciated.
One other question, any idea how much an ABS control unit goes for?
Thanks
Old 10-08-2005, 05:01 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
You have what's known as 1/4 tank syndrome... Common in older trucks... Your pickup inside the tank is going bad so what happens is that when the gas sloshes around it just can't grab any and starts to lose flow...I and others have had the same thing...Only real way to fix it is to replace the pickup which is part of the sending unit...(you have to buy the sending unit)
Old 10-09-2005, 12:24 AM
Re: Stalling 95 Jimmy
Thanks for the info! I found a certified mechanic who will drop the tank and fix it for $50. I was going to try and fix it myself, but for $50 he can have the job, plus he has a fully equipped garage to use, as he is a county mechanic who services the Sheriffs cruisers.
I will post Thursday after I get the Jimmy back, as to how the repair went.
Old 11-22-2005, 08:29 AM
BlueCamelGuy BlueCamelGuy is offline
Re: Re: Stalling 95 Jimmy
Just a side note: I was given my father's 95 Jimmy SLT @ about 184,000 miles. He had the exact same symptoms, and spent thousands on repairs and diagnostics until on the fifth try someone was able to determine that the problem was cause by the sub-injector harness which, as a factory defect, shorts itself out. I hope you already have your problem solved, but if not, here's a likely possibility.
