Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 10-08-2005, 12:53 AM
sik5hit sik5hit is offline
Unhappy What should i Do
i Have a supra turbo t top 1989 turbo car i bought for 300 bucks but it has a blown head gasket what should i do replace the gaskets or buy a new motor wat is more cheap i dont wanna spend to much money on one thing any advice will be much appreciated
Old 10-08-2005, 03:26 AM
Yellow 13's Avatar
Yellow 13 Yellow 13 is offline
Send a message via AIM to Yellow 13
Re: What should i Do
I have the exact same situation going. I just took the engine out all-together and am just making sure all the internals are good. If I were you i'd just take the head off and check the cylinder walls. If your lucky they shouldnt be scarred or anything. Its a tough block so it should be good. If you wanna go a little deeper you could take out the crankshaft and check the piston rings and bearings. Just to be safe.
Old 10-08-2005, 11:14 AM
oh ok so how did it turn out for you
