s13 with rb25det...... need inspection..... emisions is not even close. lookin for ideas for a quick fix, might be running rich, not worried about power or anything just to get it to pass. Any ideas at all. Or if any one knows someone in th MA/ southern NH area.
Re: in need of serious help
Get a friend at an emmissions shop to pass you.
or.... 1) Lean it out 2) build a downpipe with the cat an inch away from the turbine outlet 3) Get the motor really hot before going in |
Do you have a power FC?
What R.W. posted is solid.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
sorry, turbo cars spill lot of unburned fuel, i don't know if one cat can do the job (subraus have like 3?!)
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car" E.K. |
sorry to tell ya man...but i dont think ur gunna pass emissions...that motor is not meant for that car.....luckily i registered mine upnorth so it doesnt have to have emissions....ur best bet is to get a friend that is a mechanic to write u a slip sayin u spent like a grand to get it fixed...i think therer is a rule that they have to automatically pass u then...well here there is anyway...
lilskyline |
thanks for the help... i guess. im just looking for someone right now to do it for me. i have 2 months till i need to go again. so if i dont find some one im going to lean it out and hope for the best.
thanks alot tho |
Post your results.
I will help you pass. <--- ChemE major, now in Structural.
Re: Re: in need of serious help
dont have exact numbers with me but about.....
hc's was 8.02 suppose to be 2.00 co was 34 suppose to be 30 nox was just a little over due to overheating thats no biggy let me know what you think |
go to an exhaust shop and make a full exhaus out of catalics. Some guy on Nico (I think) passed a sr20 with 2 cats, 4 will most likely do it for you.
VR6> Anything FWD sucks for understeer? Swaybars do magic. |
i have no doubt that would work but where do i get the money for four cats for a 3 inch exhaust. its kind of a waste, maybe as a last resort but right now im looking for something finctional and less complicated. i got 2 months on the reject sticker and i can still get 2 more.
thanks tho in 6 monts if i have to ill use that idea. |
Re: Re: Re: in need of serious help
Reactants - Rapid Decomposition of Organic Compounds - Products Did you pay attention in chemisty at all?
Retime the engine, the HC's will dip some, but could also be as a result of too high of an operating fuel pressure. Before you test again, run the engine nearly dry. Then put about 1 gallon of 87 octane fuel in the tank with a single cap full or two cap fulls of acetone (it's a ketone that will help to atomize the fuel by reducing surface tension). It has shown to reduce HC's by a good amount. The key here is to promote complete combustion at a relatively cold temperature without the use of alcohol or any high octane aromatics like toluene or xylene, both of which are found in high octane pump fuel (~30% toluene in your average mix). The cold temps prevent the creation of NOx, which are formed when elemental oxygen is bonded to nitrogen during the high heat and pressure combustion. A catalyst will help to further reduce the HC's and scrub off some of the carbon byproducts.
Re: Re: Re: Re: in need of serious help
