Old 10-07-2005, 08:23 PM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
Exclamation Fuel Pump
88 f-150 5spd dual tanks, how do i tell which pump is goin out? when i start it it idols halfway decent, then when i give it gas it kinda dies then when i let off it kicks in. and i also have a backfire in my intake....what causes that? how can i fix it?
Old 10-08-2005, 12:11 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Fuel Pump
First check that fuel filter.
A Fuel pressure gauge will test the pumps.
The intank pumps are low pressure if it has a high pressure pump on the frame.
The low pressure intank pumps will be around 5 lbs of pressure.
Does it read the same pressure on either tank?
Depending on engine you should see 40-60 lbs of fuel pressure at fuel rail.
