Old 10-07-2005, 08:00 PM
eprince eprince is offline
battery
any body have an issue with changing battery on a 2001.
I herd that the radio would have to be reprogramed by the dealer because of the theft system ?
Old 10-07-2005, 08:47 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
True unless you have the code to unlock the radio. If you bought the car from a dealer, contact them for the code they should give it to you, or give you instructions on how to get it out of the radio.
Old 10-08-2005, 09:29 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: battery
Look at the radio. Is the Theftlock LED lit? If the little Yellow light under the word Theftlock on the front of the radio isn't lit, then the code was never set (it's a user programmed feature) and you have nothing to worry about. If the light is on, then you need code before disconnecting the battery, otherwise, your radio will lock and not work.
Old 10-08-2005, 10:14 AM
Re: Re: battery
The manual says that theftlock learns a portion of the VIN. so it won't work in another vechicle.
I get a red flashing light but I bought the car new and never set any codes. I hope that means the radio will work after replacing the battery.
Old 10-08-2005, 02:06 PM
richtazz's Avatar
Re: battery
I would probably check with a Dealer service department to be sure, but I've worked on other GM products, and as long as the Yellow LED isn't lit, you should be ok.
