Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-07-2005, 06:07 PM
golee1 golee1 is offline
1984 LTD hard starting
I have a 1984 LTD wagon with 101,000. Wednesday night I drove it 35 miles to school, started up and ran fine. WHen I got out of class I had to crank it and crank it to get it to start. In the last 2 days I've driven it twice and every time it's harder and harder to start. Just wondering whatg to look for. It has electronic fuel injection.
Old 10-08-2005, 12:29 AM
reekor reekor is offline
Re: 1984 LTD hard starting
First of all if your driving with a bad oil pump this car isn't going to run for long before you fry the motor. I aways though that electronic fuel injection did not come on these cars until 1986.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 10-08-2005, 12:51 AM
~manuel~ ~manuel~ is offline
not very familiar with this year but if it has multi port injection then i would start by checking static fuel pressure when you turn key to ON position.it should hold steady at somewhere above 30 psi.if it drops suddenly then that would indicate a bad fuel pump or regulator.
Old 10-08-2005, 01:54 AM
tommysevens tommysevens is offline
i have the same problem with my 84 5.0 tbi ...i changed everything possible!!!even brought it to a garage. they looked at it for 6 weeks and couldn't find the problem.
Old 10-08-2005, 09:48 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
At 101K start ckecking the tune up end of it.
Plugs wires fuel and air filter and check out that fuel pressure. Give it a good look over.
And do it a favor feed it the good motorcraft plugs the book calls for.
Let us know what you find.
MT-2500
