Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 10-07-2005, 05:02 PM
rlake3 rlake3 is offline
What else should be replaced when doing timing belt
I have a 98 civic and I'm going to replace the timing belt on it, what else should I replace when doing the timing belt. I'm about to it 100k miles, is there anything else I should do.
Old 10-07-2005, 06:20 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: What else should be replaced when doing timing belt
any and all other belts, water pump, thermostat, plugs, plugwires, rotor and cap...basic tune up stuff that hasn't been replaced recently.
Empty Pockets Racing Member #1
Old 10-09-2005, 12:46 PM
BullShifter's Avatar
Replace leaking cam seals & crank seals if needed. Replace water pump/coolant as already suggested. a few others : Valve cover gasket & seals, valve adjustment, drive belts(alt/ps/ac)
Old 10-09-2005, 02:55 PM
captainkirkie captainkirkie is offline
Engine light is on. Already change oil,and filter, spark plugs and wires on 00civic si vtech. what else could it be
Old 10-09-2005, 10:31 PM
Re: Re: What else should be replaced when doing timing belt
It could be many different things, the only way to find out is to retrieve the error code. Check engine lights don't come on from maintenance items.
