Old 10-07-2005, 07:19 AM
msecara msecara is offline
Unhappy Dash Lights
Problem with dash lights. Had no dash lights radio display or overhead console display when headlights are on. Display for radio and overhead work fine when headlights are off. I have changed the Headlight/Dimmer switch which temporarily fixed the problem; However something keeps blowing out the dimmer switch. I'm on my third one. I will be driving along and all of a sudden the dash just goes dark. This usually happens less than a month of installation of a new switch. Any help please.
Old 10-07-2005, 07:19 PM
Bads Crew's Avatar
Bads Crew Bads Crew is offline
I hate electrical problems. If you can't find your answer here try this site Look through the threads or post your question there.
http://www.s-10crewcab.com/og1/crewcab.htm
Old 10-07-2005, 08:22 PM
gman4ever gman4ever is offline
you could have a short in you headlight switch, or a bad ground in the dash somewhere
Old 10-19-2005, 08:21 AM
blazin around blazin around is offline
Have you changed out your radio? You must be careful with the wire coloring for speakers. Also you may need to run seperate power and ground wires if the new radio is not factory.
