Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 10-07-2005, 06:47 AM
scarecrow0529 scarecrow0529 is offline
oil question
how many quarts of oil go into a 2001 escape. i just did a oil change and i dumped in four quarts then checked it and it was at the fill line so i added another quart then i ran the car for a couple of minutes and checked it again and it is still showing a quart low. would it really take six quartz. i have been checking religiously for leaks and have not seen any. so i am at a loss ,unless it is that the damn oil is so light that i am just unclear where it is reading. thanx
Old 10-07-2005, 09:19 AM
robertdlouhy robertdlouhy is offline
Re: oil question
4.5 qts. for a 4 cyl. 5.5 qts for a v6.
Old 10-14-2005, 02:58 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
I would honestly run a full 6 qts in the 3.0L duratec due to spun rod bearing issues.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-16-2005, 02:29 AM
it looks like i will have to do 6 because i did 5 at the change and it still shows a quart low i just thought damn that cant be right. what is this about a spun rod bearing. jeez i researched the hell out of the escapes. i thought they were good read nothing but good reviews from reputable sources.
Old 03-23-2006, 01:58 PM
mtmaurer8ooo mtmaurer8ooo is offline
Re: oil question
By the way, you can't get an accurate level on the oil when doing a change until you have started the vehicle and filled the oil filter. When doing an oil change you should: Drain the old oil, change the filter, plug her back up, fill with recommended amount of oil, start and look for oil pressure to come up, check oil, and top off as necessary. That's all. MM
"Listen to me Hillary. I'm not the first guy who fell in love with a woman that he met at a restaurant who turned out to be the daughter of a kidnapped scientist only to lose her to her childhood lover who she last saw on a deserted island who then turned out fifteen years later to be the leader of the French underground."
Old 03-28-2006, 08:17 PM
Frank STL Frank STL is offline
Re: oil question
I do alot of oil changes, they take between 5.5 and 6 quarts. Depending on how long you drain the oil, and the filters may make a diff. I allways use the Fram PH2
