Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 10-06-2005, 11:20 PM
WVC2004andon WVC2004andon is offline
Intake Install
I have a 95' galant, and i need to know what wires i need to connect so it wont have the check engine light on. There was a box on the top of the stock intake that had a plug in im not sure what it is. Hopefully someone can tell me what that is, and how and what to plug into it. any help would be appreciated.
Old 10-07-2005, 09:26 AM
poordudewhowantcar poordudewhowantcar is offline
Send a message via ICQ to poordudewhowantcar Send a message via AIM to poordudewhowantcar Send a message via Yahoo to poordudewhowantcar
Re: Intake Install
In all honesty i never thought i would have bought a galant. I always imagined a cheap honda not a mitsubushi. But besides that you intake question is a problem some Si civics (99-00) have when they swap for a CAI. You have to make sure that what ever plug or wire is in the intake tube, from what a local Si owner told me it reads your incoming air.
Old 10-08-2005, 06:15 PM
mr bishi mr bishi is offline
Re: Intake Install
sounds like its your air flow meter. if its not plugged in the car carn't tell how much air is going in therefore cant injuect the right amount of fuel for the propper mixture
Old 10-08-2005, 06:20 PM
Re: Intake Install
also the plugs on the car only fit the components its meant to be plugged into.maybe the plug has fallen down behind something but if its meant ti be plugged in there wiil be a plug somewhere
Old 01-11-2006, 09:04 AM
tooch tooch is offline
Re: Re: Intake Install
yes ive looked into this myself. i own a 95 galant type-s and you need to make sure its a direct fit..it tells the comp and engine how much air is going in and that box cant be removed..its small thought right like 3x3" let me no what u did cause im considering getting one myself
Old 01-13-2006, 12:26 AM
Bronxbombr Bronxbombr is offline
Re: Intake Install
your mas box aint plugged in or you didnt reset the ecu when you installed the intake.
