Old 10-06-2005, 09:06 PM
prong2002 prong2002 is offline
Send a message via ICQ to prong2002 Send a message via AIM to prong2002 Send a message via MSN to prong2002 Send a message via Yahoo to prong2002
Thankx for the reply
Yeah I checked some more things out. I actually pulled the tank down to check for shorts and stuff. I tested the fuel pump by giving it power directly from the battery and it works. There are three wires going to the battery and I'm testing it at the connector for the fuel assembly/fuel pump on top of the tank. Some kind of weird electrical problem, the fuel pump isn't starting when you start the truck.
Old 10-07-2005, 05:56 AM
Bullet[BS] Bullet[BS] is offline
Have you checked your Fuel Pump relay? Make sure it's getting power from the ignition switch.
Old 10-12-2005, 01:33 PM
fuel pump relay
Actually I have a brand new relay installed. But, it is not completing the circuit and sending power on to the fuel pump. Without the truck being on the continuity of the ground at the relay is 120. With the truck in key on position continuity goes to 1. I still have to check it when starting. But, I know the relay is getting power I checked the orange wire.
