Old 10-06-2005, 08:38 PM
mikep1117 mikep1117 is offline
Send a message via AIM to mikep1117
best way to get more torque
I have a 95 talon tsi awd its an automatic whats the best way to get more torque.....ive been searching and seeing torque and stall converters and dont know the diffrence, this is my first auto. I was just wondering what to look for.
Old 10-06-2005, 08:50 PM
SLoe's Avatar
SLoe SLoe is offline
Re: best way to get more torque
You are talking about a torque converter. Stall is refering to what RPM it engages. It depends on the design of the converter and how much torque your engine produces. Imagine if you turn on a fan, then sit another fan in front of the first. The first fan will cause the second fan to turn even though the second has no power applied. The torque converter works the same way only it uses fluid as a medium instead of air. The Pitch of the blades is what determines the RPM you will take off at. Just remember that if you get a higher stall torque converter, you will produce more heat and reduce the life of the transmission if you don't get a transmission cooler.
Everyone feel free to correct me on any mistakes I might have made. I know you will anyway.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 10-06-2005, 09:03 PM
SLoe's Avatar
Click here for torque converters
