interior lights do not go out
interior lights on. leave door open press door swich with key in and buzzer does go out. replaced this switch. i was told it was a two position switch. door hinges were bad replaced with info from this great site. also start truck and lights still on. timer bad?
Re: interior lights do not go out
does yours have a timer? I would go to each door hinge and unplug it. They are indeed 2 way switches, one part controlling the beep and the other controlling the lights. Unplugging them should help you narrow it down. A similar thing happened to my g/f jimmy. It ended up being the driver side door switch. I took it out, opened it, cleaned it with a rag, sprayed it with a little wd-40 and put it back in. All is well. Good luck.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
I have this problem every once in a while. I think my rear hatch it loose and it rattles slightly open sometimes. To fix it i just have to open my hatch and slam it closed again and it seems to work every time
