Old 10-06-2005, 06:24 PM
redline4611's Avatar
redline4611 redline4611 is offline
new clutch and flywheel question
i have to get a new clutch pretty fast
im getting an ACT 2100. what is the difference between a 4 puck 6 puck and street plate on those clutches. which one do i need? and i want to get a new flywheel, do you think this is a good idea, if so what kind should i get?
The Real Deal
Apexi N1 Exhaust, Apexi GT Downpipe, GREDDY Type-S BOV, Dejon Intercooler Pipes, TurboXS MBC, Injen Intake, JL Audio
Old 10-06-2005, 10:02 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: new clutch and flywheel question
You definitely do not want a pucked disc unless you really know what you are getting into. They are tranny breakers, even with light pressure plates. I would suggest the street disc. I ran a 2600 with that disc into the low 11s, others have done better. I had my issues with them, but its a good clutch. I run something similar in the EVO. Same street disc with a 3000 pound plate.
I'm a big fan of the stock flywheel, machined properly. The ACT flywheel is nice too and comes pre setup for a ACT clutch. No personal experience with Aluminum FWs, so I can't comment on the other brands. Stay away from lightened stock flywheels.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-07-2005, 12:25 AM
alright
another question
not this previous summer but the summer before that, last year, my clutch was replaced and so was my throwout bearing
my mechanic tells me my throwout bearing messed up causing my clutch springs to mess up etc
how long should a throwout bearing last?
The Real Deal
Old 10-07-2005, 01:17 AM
AF - Advisor
Generally they last somewhere in the 6 figures for mileage. But they should be changed with every clutch job just because you're in there already and they're cheap.
Edit> Riding the clutch or an improperly adjusted master can cause premature TOB failure and wear the fingers on the clutch.
Kevin Jewer
