Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 10-06-2005, 06:07 PM
jasondco jasondco is offline
96 Jetta Starter Replacement Issues
I recently replaced the starter in my 96 jetta. Upon removal I found no shims. After replacing with a reman the car will start, but the starter will not disengauge and it continues to spin. Tried shimming it and lubrication but still the same symptom. Please help.
Old 10-06-2005, 08:13 PM
Ontjetta97 Ontjetta97 is offline
When you replaced the starter, did you remove the bronze/brass bushing and replace with the new bushing in the kit? This aligns the starter drive gear. If worn may cause the starter to hang-up
Old 10-07-2005, 05:52 PM
Re: 96 Jetta Starter Replacement Issues
Thank you very much for your reply. I took the starter back out and old bushing is still there... but I certainly can't get it out. It doesn't look worn...but who knows. Any suggestions on how to get it out of there would be greatly appreciated.
Old 10-08-2005, 02:14 PM
boschmann boschmann is offline
Screwdriver or small chisel & break it into pieces.
