Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 10-06-2005, 05:56 PM
dudeguy23 dudeguy23 is offline
axel and cambers
I got a few questions:
are putting in new axel's and cambers on both my front end, is it going to be hard to do? and will I run into alot of problems? and are there any tips that will make this process easier?
Old 10-07-2005, 10:49 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: axel and cambers
I know axles can be a pain if you let them... it's all about having the right tools for the job. If you do, it's easy. If you don't, it can be a nightmare.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 10-07-2005, 04:32 PM
I gota question is the 93 del sol si stock engine going to have the del sol si axel kit or the civic axel kit?
Old 10-08-2005, 01:06 PM
94SolGrl's Avatar
92-95 civic axles and del Sol axles are the same.
~*Emily*~
HOW TO POST PICS!
Old 10-09-2005, 12:38 PM
BullShifter's Avatar
Re: Re: axel and cambers
The hardest part about replacing axles is getting the axle nuts off if you don't have air tools.
Lift & support front end
Remove wheel
Remove axle nut
Remove lower ball joint nut - seperate ball joint
Remove lower strut mount bolt
Pull knuckle/brake assy. off axle
Pull out axle - may need to pry axle from trans - pry on axle not trans or you may puncture axle seal.
By "cambers" I'm assuming you mean camber kits, those will vary depending on which style you have.
The best advice I can give is buy a repair manual, I rec. factory repair manuals from www.helminc.com or you can by a Haynes from most parts stores. Make sure you have all the proper tools before starting the job & make sure to have a can of penatrating oil, it's best to soak bolts that will be removed a day or two prior to repair.
Old 10-17-2005, 01:01 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
if you have a hard time with the 32mm axle nut. pop out the center caps and lossen it with a breaker bar before jacking up the car
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-17-2005, 08:27 PM
alright I just bought the axels and camber kit.. I will update some pics when I get it finished.. this weekend is gunna be mad crazy..
