Old 10-06-2005, 03:17 PM
cbell77 cbell77 is offline
Blown headgasket I dont think so!
Today I kid wanted to take my car to a shop to see if everything is ok with it because he might want to buy it. So when we get there the guy tells me my head gasket was blown and I was like did you do a compression test and hes like no. So he shows me so oil around where the head gasket is now this tells me nothing I say well if the head gasket was blown then the compression test would tell and the car would drive like shit. He told me that a compression test would not always tell. I call this bullshit. What are your thoughts and what could this oil be I think its just a mess from some maintence in the past.
1966 mustang for sale asking $7900 call 757-766-3702
Old 10-06-2005, 03:25 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
A very small trace of oil is nothing to worry about. But if it's pretty significant where oil is leaking on the floor or over other parts of your engine then yeah maybe. From what I've learned theres only a few shops that won't shit on dsm's but most usually give you crappy advice. Have you ever changed the head gasket before?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Blown headgasket I dont think so!
Well if the headgasket is leaking to the point where there's oil running down the block, a compression test would be able to tell you a lot. This guy wants the job because it pays 9-10 flat rate hours and there's a few tricks you can to do get it done pretty quick, he probably just wants your money man.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 10-06-2005, 03:27 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Well change head gasket and sell it . Head gasket is no big deal really. Well depends, I changed mine on the RS since I drove it kinda hard. Ask a mechanic how much would they charge to to change the head gasket. You can buy head gaskets from any place and its fairly cheap but labor is what might hurt you. Check with a mechanic.
1997 Eclipse GSX
Old 10-06-2005, 03:53 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
change it yourself and buy one off ebay if indeed thats the problem.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 10-06-2005, 03:56 PM
I own a 1966 mustang no time to be changing head gasket. The gave me an estmate of 650 parts and labor.
Old 10-06-2005, 05:50 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
650 parts and labor isn't too bad depending on which gasket they're gonna use. Don't use the stocker. If it is blow, go with ARP studs.
I doubt it's blown though, check your coolant for oil and your oil for coolang, any overheating?
now - 2000 civic
soon - 2002 is300
Old 10-06-2005, 06:44 PM
The car has responded just the same as always no problems like always no overheating missing or smoke which are common with headgasket. But I have lost oil tommrow I am taking it in to see if they can find the real root of the leak. I would do it myself but damn its tight down there.
Old 10-06-2005, 06:48 PM
-Josh-'s Avatar
It could just be leaking around the valve cover and dripping down the head honestly. Let us know though.
AF User Guidelines
Old 10-06-2005, 07:34 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
what the heck does a 66 mustang have to do with a dsm headgasket?
Old 10-06-2005, 07:40 PM
Turbodog97's Avatar
Just a Neon
Wouldn't any sort of "V" engine(v6,v8) be easy to change out the head gasket because you don't have to deal with timing?
05 Srt4
97 Mx-5
Old 10-06-2005, 09:57 PM
kjewer1 kjewer1 is offline
AF - Advisor
A HG can leak oil and still pass a compression test. Consider this. The HG seperates the oil sytem, coolant system, combustion chamber, and atmosphere. Leaks can occur between any two of those points. It's entirely possible to have an oil passage find a leak to atmosphere (the side of the head/block where you would "see" the leak), but still have a good seal at the combustion chambers. But, that being said, I have never seen this happen on the turbo motors (oil leak that you can see). The NTs were famous for it in the early years, but never seen it with the turbo motors. Shit, just realized this may be an NT model in question. If, it's actually quite likely. Since it does not affect compression and performance, and its a slow leak, most poeple just leave it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-07-2005, 12:48 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
yeah but it's a 99 n/t...not the earlier ones like you said. if i was you i would clean the oil off
and drive it for a week or 2 and then see if you can see if it still leaks...if the leak comes back from the same spot (from head/block mating surface) and drips down, then your head gasket is most likely bad. if there is oil from above the block/head mating surface and it leaks down to where you cleaned the oil before, then it's not the head gasket, you're leaking somewhere else.
also where is the leak at? do you ever spill or drip any oil onto the valve cover when you fill it up with oil? i'd still clean up where it's suspicious and drive it, check out the leak, and go from there.
95 Talon TSI AWD
97 Eclipse GST
Old 10-07-2005, 08:18 AM
ted_ex's Avatar
ted_ex ted_ex is offline
You could also buy some oil dye and a light to help trace the source of the leak. Any shop will also be able to do this for you.
I'm>everything
Old 10-07-2005, 11:53 AM
Well took it in today and just my luck bad headgasket. lol 650 for ti to be done. The thing about the mustang is that I have alot of work to do on it so i dont have to time to be doing headgaskets and that stuff my mustang needs money to.
