Go Back   Automotive Forums Car Chat > Mitsubishi > Mighty Max
Old 10-06-2005, 03:57 PM
AIRTIGHT AIRTIGHT is offline
I'm Going To Attemp A Motor Swap Need Some Help
Have A Mighty Max 88 And A Motor 4g63
Will I Be Able To Use The Same Clutch And Preasure Plate?
Can I Use The Mighty Max Engine Mounts?
Old 10-10-2005, 11:13 PM
CivMoeEJ8 CivMoeEJ8 is offline
Send a message via AIM to CivMoeEJ8
Re: I'm Going To Attemp A Motor Swap Need Some Help
Does your truck have the 4G64 in it? If so, then you would be better off just swapping out the heads. You'll have to block off some of the oil and water passages but other than that it should be a direct bolt up!
Old 01-20-2006, 02:21 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
ok so this is what i have been looking for!! i just got a 94 2.4 rwd mighty max... and i have the 2.0 4g63 head.. i herd about doing the head swap on it.. where can i find more details about this?? and is the motor the 4g64 in my car?
