Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 10-06-2005, 02:45 PM
Radar12158 Radar12158 is offline
VW Jetta A/C problem
I have a 2000 VW Jetta with no A/C . The condensor fan turns on when I press the "A/C" button but no power to the clutch. I've checked the ambient temp sw & the hi pressure switch for continuity. (OK). I've also replaced the cooling fan control module. Still no luck. My A/C gauge set shows approx. 80 lbs. pressure in the system. I cant seem to be able to find the " Hi coolant temp. cut out sw" to check that.
Old 10-08-2005, 02:22 PM
boschmann boschmann is offline
Re: VW Jetta A/C problem
Are there any engine codes stored or is the CEL on?
Old 10-08-2005, 06:33 PM
Re: Re: VW Jetta A/C problem
No stored codes pertaining to the A/C. Just an inactive "overboost" code that has been fixed...
Old 10-09-2005, 08:53 PM
Certain engine codes will prevent the A/C from coming on, I'm unsure if that one would. I'd clear it anyway (free at most Autozone type stores). I'll look up the sensor location.
Old 10-10-2005, 02:50 PM
Thanks! I've looked up the sensor location in my "Bently" manual & it's supposed to be in the "Upper T hose between the cyl head & the radiator" but there's nothing there. VW must have stuck it somewhere else......
