Old 10-06-2005, 02:20 PM
wakeboard1026 wakeboard1026 is offline
Send a message via AIM to wakeboard1026
Exclamation help with clutch quick -homecoming dance is in 1 week
Last night when i parked in the garage everything was fine. but when i get in my car this morinig there is no resistance ont he clutch and it isnt engaging b/c it grinded when i tried to put it in reverse.
I have a 97 3000gt sl with 50,000miles, and the homecoming dance is in 1 week and i dont want to drive my girlfriend there in my moms honda.ive asked a couple people so far and they mentioned cables, and a master cylinder, etc. So if any one has any suggetions it would be appreciated.
Old 10-06-2005, 02:46 PM
sLADe781 sLADe781 is offline
Re: help with clutch quick -homecoming dance is in 1 week
Yeah, if you push down on your clutch and there's no resistance, try checking your master cylinder. You may be empty...
Old 10-06-2005, 04:19 PM
i just filled up my clutch resevoir with dot 3.i also looked on the back of the transmission where the lever sticks out that disengages/engages the clutch and it moves barely when the clutch is depressed, though i have nothing to compare it to b/c iv never seen what it does normally. but what is a master cylinder?
Old 10-06-2005, 05:18 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
The master cylinder is the thing that you poured fluid into.
You may have a leak. If your fluid was low, then you most likely do.
But if there's no leak, then you need to bleed the slave cylinder to get your clutch pedal back. Same exact method as bleeding brakes.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 10-06-2005, 07:01 PM
ive been researching the master and slave cylinders, and the problem does seem to be in one of those i just dont understand how i can park, sleep, get back in the car and have no clutch resistance. there isnt even any fluid on the floor so i dont think it is leaking.
Also, when u look under the hood and see the lever that controls the clutch,( so i can troubleshoot) where is it supposed to rest when the car is off, mine is leaning towards the right left tire, and that is the direction that the slave cylinder pushes it, so u would think it is supposed to rest in the opposite direction ( towards the left front wheel) so that when u press the clutch it disengages it, and when u release it, it goes back. So is the problem here?,in master cylinder?, slave cylinder?, or hose?, and if it is any of the above is it a doit yourself project?
Old 10-06-2005, 08:00 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: help with clutch quick -homecoming dance is in 1 week
I blame the fluid gnomes. They are greedy little bastards. Seriously. I parked my car one night. Left for work in the morning and knew immediately the clutch felt weird. I started powershifting so I could at least make it to work. I thought my master had finally died since my slave was only over year old. I added brake fluid and bled it. THe car has been fine since and not lost a drop. I know of a few other people it happened to also. Its a mystery only the gnomes can solve.
Old 10-07-2005, 10:49 AM
lol gnomes...well i guess that's good advice
Don't worry about where it's resting for right now...the fact that it barely moves means you need to bleed it. So grab your 8mm wrench and get somebody to help you bleed it. The bleeder screw is on the slave cylinder FYI. Try that...should take a half hour or so, come back w/ results.
Old 10-07-2005, 10:53 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
I bled mine myself, but that's most likely the problem... if it's just started... I'd give it a couple of weeks b4 that cylinder is gone or makes you eat that clutch...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-07-2005, 10:55 AM
Mikelb's Avatar
I'd say just buy a new master cylinder to make sure, but be sure to go ahead and check the slave while you're at it... it saves time to replace both at once, rather than one now, and the other a few weeks later (I know from experience)... it actually saves money, b/c yo only gotta buy fluid once...
Old 10-07-2005, 11:26 AM
yea thats probably what im going to do is replace the master and slave at one time because i dont see how the clutch fluid can disapear after just sitting in the garage, the problem has to be in one of the two right? And can some one show me a picture of which 8mm nut to bleed it with or better describe it. thanks
Old 10-07-2005, 11:29 AM
http://images.autopartsworld.com/liv...0100659ASC.JPG
is the silver piece with the tapered end the one i bleed?
Old 10-07-2005, 11:56 AM
Igovert500's Avatar
blue + red light magnet
http://www.stealth316.com/2-clutchbleeding.htm
And chances are it leaked out as you were driving over time, and then it finally just lost the last little bit as it sat. That is how it happened to my friend's Maxima a few weeks ago. Inspect the lines, on his, neither cylinder was leaking, just one of the lines had a small hole in it.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-07-2005, 05:12 PM
Stealthee's Avatar
It happens. I swear it. LOL. Dont replace the master if its not needed. It is a chore. Look under the dash. If there is brake fluid by the clutch pedal then the master is bad. If not dont bother with it.
If you dont have anyone to help you bleed it then open the resevoir, crack open the bleeder valve on the slave and wait. Its gravity bleeding it. I usually let it drain down half way, fill it, let it get half way, fill it, then let it get half way again before I close the valve and top off the resevoir. Works every time.
Old 10-07-2005, 07:42 PM
Thanks yall, i just ordered a new slave, and im pretty sure thats the prob cuz i see a little fluid around the black seal. And i got some buddys to help me bleed it, itll probably get here around sun/mon. and ill tell yall what happens, thanks again
Old 10-07-2005, 07:48 PM
WOW, i never thougt to look under the pedal for the master, and there is little bit of fluid around the edges, please dont tell me i need to buy the master also.
