Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-06-2005, 11:45 AM
Benag Benag is offline
How reliable is AutoZone?
I'm having a prob with battery alternator complex... My car wouldn't start without a jump and when shut off wouldn't start again without another jump. I took the alternator out and went to AutoZone and they tested it and it was fine. So I take it back and reinstall it and decide to just take my car to the zone for testing the battery. After the jump and on the drive up there I guess I fixed a bad connection because it began to work fine. I could start it alone and it was perfect. That was a week and a half ago and now it is doing the same thing again. Could I still have a bad connection still? Was AutoZone right about the alternator? Do I just need a new battery...? Thanks and sorry for the long ass explanation.
'95 Eclipse GS-T
5-Speed
Boost, air/fuel gauge.
Old 10-06-2005, 12:28 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: How reliable is AutoZone?
Is there corrosion around the battery terminals?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 10-06-2005, 12:42 PM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: Re: How reliable is AutoZone?
That is what it sounds like to me. Just clean up the connections man and it should be fine. Get a wire brush to knock all the corrosion and or grease/dirt whatever it may be.
Old 10-06-2005, 02:55 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Also, an easy way to clean off the corrosion without all that green crap flying all over the engine bay, is with a can of Pepsi. Pour some in a cup and then dip the battery terminal in the soda. Allow it to sit a couple of minutes, rinse with water, dry and reattach.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-07-2005, 09:48 AM
I'd go with Coca Cola it is more potent.
Old 10-07-2005, 10:11 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Pop is pop, you could use root beer if you wanted and it would do the same damn thing. It's the acid that counts, every pop has it.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-07-2005, 10:18 AM
I know but some pops have a higher concentration of acidic contents. I'm pretty sure Coke has the highest too. That is why I said that. Don't get all bent out of shape it isn't like im promoting I don't even drink pop. Geez
Old 10-08-2005, 12:07 PM
inatalonIXLR8 inatalonIXLR8 is offline
I've always found a lot of baking soda with a little water to eat corrosion right up. I'm not completely sure, but I don't think you are supposed to turn a batt upsidedown. Then when it's all clean add a little petroliem jelly on the terminals to keep it from corroding again.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 10-11-2005, 07:42 AM
I was talking about the battery terminal not the battery post.
1997 Spyder GS-T
5-Speed
