Old 10-06-2005, 11:47 AM
cstanley cstanley is offline
fuel problems
I am having problems with a '93 Cav rs. this car will start when it is cold & run until it warms up, to running temp. But will not start until it cools off again, does not seem to be getting any fuel when warm. I don't have any codes to out of the ecm now. Any ideas would help
Old 10-06-2005, 05:50 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
if you KNOW its not getting fuel i'd start with the fuel filter, it could also be a the fuel pump, can you hear the fuel pump when you turn your key right before your engine starts???
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-06-2005, 06:28 PM
Re: fuel problems
I've changed the filter, yes & when it is cooled off then you can hear the fuel pump before it does start, but when it warms up & when I shut it off then you don't hear the pump run until it is completely cooled off.
All of this started after I had to change the head gasket on this 2.2 engine. I did have to replace the MAP sensor, which I thought would cure this problem, but to no avail. I changed the fuel pump in this car about 5 monthes ago, which I really didn't want to do it again, but I maybe have to before I am through-thanx
Old 10-15-2005, 02:03 PM
dizel326 dizel326 is offline
Re: fuel problems
check your fuel pressure with a pressure gauge to see if you're getting 100-120p.s.i. could be an injector .
