Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-06-2005, 11:27 AM
mike mallon mike mallon is offline
Question 1991 mustang power window problems
I Have A 1991 Ford Mustang And My Windows Won't Work. I Have Checked All Fuses. I Have A Chilton And It Shows Nothing. Are There Any Relay's Are Fusable Links. A Have A Ok Understanding On Electrical Stuff But Just Can't Find The Problem. If Any Budy Can Help Thanks.
Mike
Old 10-13-2005, 01:47 AM
fordforlife's Avatar
fordforlife fordforlife is offline
Re: 1991 mustang power window problems
are the motors making any noises at all? if possible, can you disconnect the motor and put a multimeter or test light on the wires going to the motor to see if its getting juice. It could just be the gears in the motor as well.
Old 10-25-2005, 02:27 AM
Corey170 Corey170 is offline
Me Too
I have a similar problem in my 91 stang. the driver side window works fine but the passenger doesn't work. It goes down but not up (not very helpful). ive checked the motor, gears, and switches, and they're all fine. Any help on this would be great.
Theres always something wrong with every car.. ALWAYS
Old 10-28-2005, 04:39 AM
Kathmandu Kathmandu is offline
There is an overload relay somewhere in the car that disconnects the motor when it reaches either the up or down limit. (battery saver switch) it could be a position switch in a 91, not sure. I have a similar problem but I have no idea where this might be located because it isn't in the door.
I suspect it may be in the trunk on the driverside fender on mine where the lock control relays are and the security system.
Old 10-29-2005, 03:06 AM
KimMG KimMG is offline
AF - Advisor
Do you have a wiring diagram? Having an enlarged copy of the diagram makes it easier to read and mark off the circuit as you check each component.
Autozone.com may have a copy online if you need one.
Old 02-28-2007, 12:28 AM
smurfmobile smurfmobile is offline
as a bodyman i can tell you if you've checked conn. wires, try manuelly rolling the window up and down with pos, and neg, jumper wires two or three times. alot of times the track is binding with the window, or the regulator motor is going bad, it may work once or twice but it will get slower and slower till it stops.
Old 02-28-2007, 12:56 AM
thanx for the info, but i actually have someone buying the car on thursday (i got a new car.. 240sx). so i dont have to deal with that problem anymore. YAY, NO MORE FORD!!!
Old 03-04-2007, 03:50 PM
NJH_Habitatpro NJH_Habitatpro is offline
Send a message via AIM to NJH_Habitatpro Send a message via Yahoo to NJH_Habitatpro
Good luck with the 240 it will be just as bad. If not worse.
Old 03-06-2007, 05:21 AM
ya right buddy. i got it for 4 grand and its only got 100 clicks on it. im just glad i dont have that pos ford sittin in my driveay anymore.
Old 03-06-2007, 11:27 AM
351wStang's Avatar
351wStang 351wStang is offline
A buddy of mine went from a '95 escort to a '93 I think 240sx and had nothng but problems with the nissan.
1969 Cougar
357w & TKO - 475hp
Old 03-06-2007, 03:49 PM
well im obviously not gonna win this battle in a mustang forum. but theyre good cars...
Old 03-06-2007, 03:51 PM
im sure if i had a 5.0 L i wud have a different opinion. but i had a 2.3 and it was slow as fuck. the 240 rips it off the line and ive never lost a race.
