Old 10-05-2005, 10:32 PM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
Having a bad day?
97 Blazer LS 154K miles.
My blazer is in pretty good shape right now,[knock on wood], and usually is pretty dependable in my day-to-day driving. i have not driven it harder or 'softer' at all recently, its usually pretty consistent. well today, i had a weird day because the 3 or 4 times i started it to go from place to place, there was a slight gulp if you will, in the motor upon startup. the rpm's dropped below 1000 for a hair of a second then came back up and idled rough until i would give it some gas and give it a few secs to re-coop. did this a few times. i checked the oil although its under its regular service- looked good. i checked for leaks, smells, any sort of damage under the hood or to the underbody - looked good. gas was at a 3/4 of a tank. then tonight, it started up fine with no rough idle whatsoever or sign of above-said problems. just wonderin what would cause the weird occurences or if anyone has opinions/suggestions?
Thanks, Ryan
Old 10-05-2005, 11:02 PM
drdd's Avatar
drdd drdd is offline
Re: Having a bad day?
this could be lots of things but ... I'll start ...
u ever changed your fuel filter ?
Thanks, Ryan
Old 10-06-2005, 05:09 AM
DINO55's Avatar
DINO55 DINO55 is offline
Bigry2004
When was your last complete tune up? What did you replace when it was done?
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 10-06-2005, 01:28 PM
Re: Re: Having a bad day?
not since i bought it.
as far as the tune-up goes, one was done a few months before i bought the blazer, according to the guy i got it from [family affiliate].
Old 10-06-2005, 01:30 PM
Cailen Cailen is offline
Tune up thread would be a good place to start bro. Stickied at the top of the forum.
Old 10-06-2005, 10:21 PM
97BlazerDude's Avatar
97BlazerDude 97BlazerDude is offline
I am not sure what part of a tune up would solve his wierd problem. It would more likely be a waste of $100. I would check the air filter and clean the throttle body - they are easy and free.
I can wear a blazer. I can drive a blazer.
Old 10-06-2005, 11:02 PM
OverBoardProject OverBoardProject is offline
Banned
And replace that fual filter.
A plugged fuel filter will kill your fuel pump, and that gets expensive
Old 10-07-2005, 09:43 PM
ok, i will check the forum for the location and how-to on replacing the fuel filter and will look into cleaning the intake/throttle body. thanks for the help guys!
Old 10-07-2005, 11:34 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Re: Re: Having a bad day?
How long have you driven that Blazer since it was "new to you"? GM admits even their premium platinum plugs (which may have been equipped in that truck engine at that model year) do not last a lick beyond two years of "regular use". And we all know what GM means by regular use - never squeezed more than 1/4 throttle on a closed loop. (Just kidding!)
Old 10-07-2005, 11:41 PM
Re: Re: Re: Re: Having a bad day?
haha thanks wolf. i wasnt aware of the length of spark plug usage. i will replace them soon.
