Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-05-2005, 09:42 PM
shooitzlinh shooitzlinh is offline
96 itr rotors
i want to buy 96 itr 4x114.3 four wheel disc brake setup but i came up with the issue of replacing the rotors. i dont want to swap out to prelude rotors/calipers. Does anyone know where i could just get a oem replace rotor for the 96 itr?
Old 10-06-2005, 08:41 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
well you got a few problems here because for one I belive all ITR have 5 lugs so you aren't gonna find a 4X114.3 that came off an ITR. Second we didn't get type R in the states till 97 so 96 you would have to go to japan for.
Why not just get a normal integra brake swap for your civic? it would be more than a powerful braking system on that car, and you could just buy replacement parts at your local parts place.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 10-06-2005, 12:04 PM
No i believe i am correct they do have 96 itr with 4x114.3 its just that they didnt come to the states. And my purpose for this lug pattern is for different wheel choice since i want to go with sprint hart cp-r wheels..
Old 10-06-2005, 01:16 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: 96 itr rotors
Yeah the older ITR's did have the 4x114.3 bolt pattern. But yeah, if you want an OEM rotor then you'll need the honda part # (if honda can actually get it for you). Also Accords (probably not the newer ones) have that polt pattern as well, something to look into.
Old 10-06-2005, 01:57 PM
knorwj's Avatar
sorry should have been more clear. What I meant was that you aren't going to be able to buy parts easily for a car that never came here meaning the 96 itr. And that you should look into finding a vehicle that did come with that bolt pattern that also was available here, or change the bolt pattern to a more readily available one.
Old:
New:
Newer:
Old 10-06-2005, 04:39 PM
Re: 96 itr rotors
i could switch over to prelude/accord calipers/rotors but i just wanted to see if there was just a direct replace before i go threw that hassle
