Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 10-05-2005, 08:57 PM
ScottsTown ScottsTown is offline
Question Dimmer wire for headunit
Hey all,
Ok, I have a simple question, although i can not figure it out. I have a 89 honda civic hb, with a pioneer deh-34 head unit. I am trying to make the head unit dim with the rest of the dash.
The headunit has a wire with dimmer written on the side of it coming out the back. And I ran a test wire from the back of the dimmer control to the other wire, but it will not work for some reason.
The wire coming out of the dimmer control is 12+ when off, and 0 when on. Does anyone here see what I am doing wrong, thanks scott
Old 10-05-2005, 11:15 PM
donalduck_69 donalduck_69 is offline
Re: Dimmer wire for headunit
Did your factory radio dim with the lights? If so, there should be a wire in the factory harness that will do what your asking. Not sure what color it would be but if you got an adapter then you should be able to figure it out. Anyway, if that won't work, you could, but I wouldn't condone, giving the wire a positive signal and see if that does it. But it's your fault if the unit fries. I warned ya. Good luck.
Nate
97 Prelude
*DC Sports 4-2-1 Header
*AEM Intake
*RSR Exmag Catback Exhaust
*DC Sports Short Shift Adaptor
*Two Way Alarm
*Piaa Super White Headlights
*Momo Shift Knob
*Black Suede Headliner
*All Black Interior (changed from tan)
*Alpine CDA-9835 Head unit
*JL Audio 3 way components powered by Alpine MRD-345
*1 12" Eclipse Titanium powered by Alpine MRD-1005
*Dynamat Extreme everywhere and Monster Wiring throughout
*Alpine KCA-420i IPOD Interface
*Skunk2 OBD I Race Computer
Old 10-05-2005, 11:49 PM
Thanks for the info Nate, yeah i got the car with no radio installed, so i dont know if the factroy one dimmed or not. But still thanks for the info. Scott
Old 10-06-2005, 12:37 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
well, first and foremost I'd make sure that the dimmer is on on the headunit. I've had 3 pioneer decks and I've had to turn the dimmer on with all three of them.
I'll look for a wiring diagram and see which wire from the factory harness is the dimmer wire. They do dim, I had a 90 Civic EX and the cd player dimmed along with the clock and everything when I hit the headlights.
Empty Pockets Racing Member #1
Old 10-07-2005, 05:06 PM
Copytech99 Copytech99 is offline
The dimming may need to be enabled as mentioned.
Old 10-08-2005, 11:36 AM
How would I go about enableing it? thanks scott
Old 10-08-2005, 12:03 PM
wakeboard_dude5 wakeboard_dude5 is offline
Send a message via AIM to wakeboard_dude5
I've never heard of having to enable dimming... but i found a wire diagram that might help you out. It says it might be different for different years, but its a good place to start. good luck with this
1993 civic EX coup auto SOLD! but i'll miss her
1996 Civic CX w/ B18c1 swap, small bolt on's, 2000 front end
Old 10-08-2005, 12:28 PM
On my DEH-P4400, With power off hold "function" it will give options for clock set and also dimmer option can be set on.
Old 10-08-2005, 01:37 PM
GScivic7's Avatar
every aftermarket headunit i've come across has a the option of turning on or off the dimmer.
Old 10-08-2005, 02:39 PM
wow duh sorry. When i read that i thought it ment something inside the car NOT the radio. but that diagram i saw was at http://carstereohelp.net/wireharness_Honda1.htm so i hope it helps you out.
