Old 10-05-2005, 05:19 PM
Bobbywolf Bobbywolf is offline
Lights dimming.
95 escort LX. The car has been preforming well as of late, but one thing that is odd, is when I am driving and turn my heat on, all my lights on the car dim to about 50% for a second, then back up. Looks like I am flashing my beams at oncoming cars when I turn on the heat. Is it possible that my fan is drawing too much current? Or maby just a weak alternator? The car still charges fine when running, and I have never had a problem with a dead battery so I think the alternator is good.
Any suggestions on things to check?
Old 10-05-2005, 08:42 PM
Lynde Lynde is offline
Re: Lights dimming.
First of all, turning your heat on isn't gonna cause your fan to come on. Your defrost mode might, and will cause your A/C clutch to cycle.
Sounds like your brushes in your voltage regulator are starting to go bad. Sometimes you can't buy it seperate from the alternator. Try doing a charging test. Starting with the battery.
Old 10-06-2005, 03:34 PM
Re: Re: Lights dimming.
Well, it was a used alternator when I replaced it last year, so that may be the issue. Can I check the current output by simply putting my ampmeter in series with the positive line coming off the alternator? Or is there a better way of testing this thing?
Old 10-07-2005, 06:37 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
My car does this whenever I turn the A/C on. It's caused by the initial draw of the cooling fan motor coming on. Do you have the A/C button pushed in?
Nevada Tumbleweed
Old 10-08-2005, 09:44 AM
Re: Lights dimming.
Definatly not, its far too cold to use the A/C
There is indeed a fan that starts up, so far as I can tell it must be drawing too much power initially. I'll try another alternator from the boneyard to see if my results differ, I'll return it if not.
Old 10-08-2005, 10:18 AM
Re: Lights dimming.
Forgot that it's cold some places. I'm in Yuma, Arizona. If the cooling fan behind the radiator is coming on then a momentary dimming is probably normal.
Nevada Tumbleweed
