| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
i have a 95 GSX. first off, i tried to start it one morning, and it ran like shit, after having ran great the night before... no boost pressure; fluctuating idle; raw gas smell; plugs wet with fuel; fuel in oil pan; white exhaust smoke.
there is a click in the dash, behind where the radio would go... i dont know what that is.. idling low; and fluctuating idle. i have to hold the throttle down a little to get it to idle anywhere near right. i have replaced both O2 sensors; mass airflow sensor; MDP sensor. also i have fuel in my oil pan. when i take the plugs out they are wet with fuel, and there is a smell of raw fuel. i thought it was the crank angle sensor, or a coil pack, but the plugs all fire when i take them out. also.. should the injectors fire when i turn it over with the plugs out? the fuel shoots out the tip of the cylinders... PLEASE HELP.. MUCH APPRECIATION |
Re: Serious Help Please
The injectors should shoot fuel out when you crank it because you are energizing the fuel pump when you crank. I don't know about firing, but they should definately spray fuel. I mean I don't know why you would replace your o2 sensors if you have fuel in your oil pan. It sounds like a problem with your fuel system. Try checking all your lines, injectors and since you are getting fuel in your pan check your cylinders you may have fucked one up.
1991 GSX 2.3 Stroker |
Make sure your injectors are still seated in the head properly. This is difficult to diagnose because it has like 4-5 problems that stem from 1 thing. post back when you have any more info.
now - 2000 civic soon - 2002 is300
it's not just fuel in the oil pan... i think that comes from where the car wont start all the time, and it drains into the oilpan.... the thing is that the car doesnt run right; the computer said MDP sensor; Mass air flow; i replaced all those... it is acting like an induction problem sorta. i dunno. there is a little click int he dash when i turn the car over. a single click every time.
