| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
brakes bleeds down
i have a 92 ford f250 deisel.....and we replaced the master cylinder rear wheel cylinder and calipers...bleed the system manually and with a brake flush machine...and still bleeds down when vehicle is turned on???whatelse could it be?? booster? vacumm pump???
Re: brakes bleeds down
Is the power assist vacuum or hydro-boost? If it is vacuum assisted, a bad pump will give a harder than normal pedal. If it is hydro-boost, check fluid level. When you replaced the master cylinder, did you replace it with the same size bore in the master cylinder? I have replaced m/c and found out the bore was smaller and caused bleed off.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
Re: Re: brakes bleeds down
i got a new master cylinder cause the last one was leaking behind master cylinder.....but when i benched bleed it...it got very hard...so i let sit over nite and try again in the morning....but TY for your advice....if u find out anymore then let me know..i will check back in the afternoon...ty |
