Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 10-05-2005, 03:37 PM
96HondaCivic 96HondaCivic is offline
Really bad noise
I have my stock 14 inch tires and rims on my civic. When i am driving around 60 there is this humming sound like the same tire sound the huge trucks make. When i press ont he brake pedal pretty hard it gets like 5 times louder and starts to shake a little bit. My brake pads have about 10% life in them, can that be the problem? The wheels are torqued to spec.
*- '96 Honda Civic Lx 4 Dr Auto -*
*- CAI 2.5in w/aem bypass -*
*- Invidia High Performance Cat-Back Exhaust -*
*- Suno Hyper Ground System -*
*- Front Upper & Rear Upper Strut Bars -*
*- Dc Sports Rear Lower Strut Bar -*
*- Tom's Lowering Springs 1.5in -*
*- 16X7 Konig Blatants w/ 215/45 Falken Azenis -*
*- Power Stop Slotted rotors -*
*- G-Force 5 Points Harnesses(Only using 4 points) For autocross -*
Old 10-05-2005, 09:08 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Really bad noise
Humming could be cupped or feathered tires. Do they look good?
The shaking while braking is usually warped rotors.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 10-05-2005, 09:22 PM
The tires are really old. Me and pops found out it was something with the tranmission. I am going to get a tranny fluid chagne tommorow.
Old 10-06-2005, 12:13 AM
BullShifter's Avatar
Changing the fluid will not fix an internal trans problem, it's likely to make it worse.
I agree with both comments from CivicSiRacer. Might even be a wheel bearing. Noises are hard to fix without hearing since everybody's description is different.
Old 10-06-2005, 07:34 AM
I am pretty sure the fluid has not been changed for 144k miles.
Old 10-06-2005, 07:44 PM
tomsindahizouse tomsindahizouse is offline
Send a message via AIM to tomsindahizouse
Like Bullshifter said....
"Changing the fluid will not fix an internal trans problem, it's likely to make it worse."
...and instead of getting it changed...try doing it yourself.
2000 Civic Si
98 Civic Dx
Old 10-06-2005, 10:32 PM
Your best off leaving it alone and if it needs fluid just top it off. Remember Honda transmissions are checked with the engine off.
If you really think it's the trans I suggest taking to a trans shop for proper diagnosis and recomendations. If they won't change the fluid I don't rec. doing it yourself either.
I still think it's a wheel bearing or bad tire.
