Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-05-2005, 03:30 PM
tr1ck.gSx tr1ck.gSx is offline
Exclamation Need Serious Help
i have a 95 GSX. first off, i tried to start it one morning, and it ran like shit... no boost pressure; screwed idle; raw gas smell; smoking.
there is a click in the dash, behind where the radio would go... i dont know what that is.. idling low; and fluctuating idle. i have to hold the throttle down a little to get it to idle anywhere near right. i have replaced both O2 sensors; mass airflow sensor; MDP sensor. also i have fuel in my oil pan, and when i take the plugs out they are wet with fuel, and there is a smell of raw fuel. i thought it was the crank angle sensor, or a coil pack, but the plugs all fire when i take them out. also.. should the injectors fire when i turn it over with the plugs out? the fuel shoots out the tip of the cylinders... PLEASE HELP.. MUCH APPRECIATION
Old 10-05-2005, 06:05 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Don't post the same thread in multiple sub-forums.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-06-2005, 03:04 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Need Serious Help
fuel pressure regulator? injector(s) stuck open? check out things like that.
95 Talon TSI AWD
97 Eclipse GST
