Old 10-05-2005, 01:15 PM
nathank's Avatar
nathank nathank is offline
Swapping intake gaskets on a 5.3L
After troubleshooting my cold start issue for a month now, I am being told it is most likely intake gaskets.
For anyone who has swapped intake gaskets on a 5.3L please feel free to chime in with any advice that might help with this process. I don't anticipate it will be all that difficult, but I have never worked on a 5.3 before so I am not real sure.
I picked up the gaskets and they are hard plastic with rubber around the port areas. Is it necessary to use silicone on any parts when bolting the intake back on?
From what I can tell the intake torque specs are
1st pass - 44 in/lbs
2nd pass - 89 in/lbs
All help is appreciated!
Old 10-05-2005, 01:20 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Swapping intake gaskets on a 5.3L
I looked at a shop manual for this procedure when I thought mine were messed up. I decided not to mess with it...more power to ya man.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-05-2005, 01:30 PM
nathank's Avatar
Re: Re: Swapping intake gaskets on a 5.3L
Why did you think they were messed up?
Old 10-05-2005, 01:37 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
While you've got the intake off, you might as well go ahead and change your knock sensors, because they are located under the intake manifold
http://www.automotiveforums.com/vbul...17#post2613117
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 10-05-2005, 01:46 PM
nathank's Avatar
Great, how much do those cost?
99 Z71
00 Tahoe LT
Old 10-05-2005, 01:53 PM
jeverett's Avatar
Re: Re: Re: Swapping intake gaskets on a 5.3L
I had a bad coolant leak that I couldn't spot outside the engine anywhere, so I had it checked and the head gasket on the driver side was cracked.
It leaked 3 resivors of coolant in the oil before I found out. It later caused my engine to spin 4 bearings.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-05-2005, 02:53 PM
Re: Re: Re: Re: Swapping intake gaskets on a 5.3L
That just sounds like it's time to change the engine
Old 10-05-2005, 02:55 PM
About $40 each, and there's two of them
Old 10-05-2005, 03:04 PM
nathank's Avatar
Ouch, I think I'll take my chances with the ones in there.
99 Z71
00 Tahoe LT
Old 10-05-2005, 04:17 PM
jeverett's Avatar
Re: Re: Re: Re: Re: Swapping intake gaskets on a 5.3L
I did, about 30K ago. I'm waiting on this one to crap out on me. I want a 6.0 or a built 5.3 or something like that.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-05-2005, 04:29 PM
nineball481's Avatar
nineball481 nineball481 is offline
Just take your time. Don't loose any parts. It could be helpful to take pictures before you start. Don't force anything off, there may be a hidden bolt. Once you get everything off you should not need silicone for the gasket, it should seal itself. I would recommend getting a Haynes or Chilton manual and read up on the procedure. Those books are handy to have around anyways. Use common sense! Everything should go smoothly.
Once it is back together and you start it and it runs like crap, you have left a sensor or vacuum line disconnected.
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 10-10-2005, 08:44 AM
nathank's Avatar
Completed the swap this weekend. Everything went great and it seems to have cleared up my issue. Thank you all for your help, it is appreciated.
99 Z71
00 Tahoe LT
Old 10-10-2005, 08:51 AM
jeverett's Avatar
Glad to hear it man!
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-28-2005, 12:05 AM
Sublime69 Sublime69 is offline
I might need to change mine, how did it go? How long did it take??
Thanks
Old 10-28-2005, 08:15 AM
nathank's Avatar
Thanks
It actually wasn't as bad as I thought it was going to be. It took 3 hours or so, but I made sure to clean everything up real well. My throttle body and intake was gunked up so I cleaned all that up real well. I also spent some extra time prepping the intake where the old gaskets were.
Only special tools I had to go get was a 1/4 torque wrench to handle the BIG inch pound torque job. 44in/lbs first pass and 89in/lbs total.
Also, I didn't have the fuel line disconnect tool, so I pulled the injectors from the intake. If you do it this way, be sure to lube those rubber O-rings on the injectors or they won't slide in very easily.
99 Z71
00 Tahoe LT
