Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 10-05-2005, 11:59 AM
byrdcar byrdcar is offline
Keypad code for 2000 Grand Marquis
Just bought a used 2000 Grand Marquis and would like to use the kepad on the outside door, the owners manual says that there is a code on the owners wallet (dont have) or taped to the computer module, now under the dash I know where the plug in terminal for the computer is but there is nothing taped to that, am i looking in the wrong place
Old 10-05-2005, 02:31 PM
h036y23 h036y23 is offline
Have you looked in the trunk ? There is a string you can pull to unlock the trunk from inside. It has a tag with numbers.
Old 11-10-2005, 10:49 PM
AngelD AngelD is offline
Re: Keypad code for 2000 Grand Marquis
I just bought a 2003 Grand Marquis myself and I've into the same problem, and I've seen the same thing you did, the big plug under the dash. I was told by the dealer I bought it from that the code is behind the passenger door panel. I would be very careful, however in trying to remove the panel. I haven't done it on mine because I don't know how the panel is attached. Pulling on it might break a clip or something.
Old 11-15-2005, 11:29 PM
vtwindave vtwindave is offline
the code should be in trunk, my 95 code is on trunk lid arm, pax side
Old 11-16-2005, 09:21 PM
BiggerJon BiggerJon is offline
Re: Re: Keypad code for 2000 Grand Marquis
fyi to everyone.
when these cars are sold to a customer there is no automatic location for the stickers you are all looking for.
the new vehicle owner can put them anywhere they want. look everywhere. if you cannot find one, contact a dealer. they may be able to get you the master code from the VIN number.
Mods
Old 05-20-2007, 08:36 AM
urbanator urbanator is offline
I too found mine in the exact location!
Old 07-02-2007, 12:35 PM
dwyczalek dwyczalek is offline
My sister has a 1997 Ford Crown Victoria and My Father In-Law has a 2004 Lincoln and he had a 2003 Lincoln before that that he totaled out and they all were on the trunk hinge but I'm preety sure it was on the drivers side hinge not the passenger side.
Old 07-03-2007, 06:38 AM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
I had programmed in a code easy for me to remember on my 98 and lost the factory code. The dealer told me they could retrieve it from the car's computer but would charge me 1 hour labor ($75). I got the code for my 06 and wrote it in the owner's manual.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
Old 08-28-2007, 08:27 PM
jeeperphil jeeperphil is offline
my 2003 code is on module under driver seat. i was told all 03 and up are located there.
Old 09-10-2009, 09:28 PM
jwcolby jwcolby is offline
On the passenger side truck hinge is where I found mine (after reading this thread)
Old 06-29-2014, 11:06 PM
getfreducated getfreducated is offline
Thumbs up Re: Keypad code for 2000 Grand Marquis
It was indeed located on the trunk hinge on the driver's side. White sticker about 2" long with the code in bold black. It worked great!! I was so happy (since there are 3125 possible codes in all).
