Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-05-2005, 12:25 PM   #1
BLINK54321
88 MUSTANG NO fuel NO Spark
First my fuel pump wasn't priming when the key was turned but i DID jump the relay with a cotter pin and the pump turned on and as i cranked the car wile the pin was in priming the pump, it didnt turn on so i took a plug out and tested for spark and theres no spark my mechanic says it coud be a million diff things but he says one thing is causing both of the problems cuz i got a new relay and it doesnt prime the pump but when i jump it it does, i need HELP quickly and the first couple forums were like mine so i think this probably happens alot with these old school stang.
BLINK54321 is offline   Reply With Quote
Old 10-05-2005, 04:31 PM   #2
fordforlife
fordforlife's Avatar
Re: 88 MUSTANG NO fuel NO Spark
check your grounds
fordforlife is offline   Reply With Quote
Old 10-05-2005, 10:50 PM   #3
HiFlow5 0
Stanger
HiFlow5 0's Avatar
Send a message via AIM to HiFlow5 0
Well don't worry about the fuel just yet. You have no spark, you need to start there. Find out why you don't have spark. It could be a ton of different things, but start small. Area's such as the coil, wires or distributor. How are you checking for spark to find out you don't have any?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
HiFlow5 0 is offline   Reply With Quote
