Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 10-05-2005, 08:26 AM
djd99's Avatar
djd99 djd99 is offline
Help Electrical/Ignition problem
Howdy I have a 96 Sunfire with a 2.2 that just died going down the highway. However It did throw a camshaft position sensor code before it Passed. Ever since then It will crank but not even attemp to fire, although it did cough once. I sprayed starting fluid in the intake and still didn't attemp to fire so I guess I rulled out a gas issue. I check the spark and found a red weak spark. So for giggles I had a extra camshaft sensor laying around and swapped them out and still cranks but does not even attemp to fire. Does anyone no where or what I should attemp to do next. Shouldn't the spark be blue?
2000 S10Blazer LT 4 Door 4x4
Billet Grille insert
Winter 30X9.5QR15 BFG's All-Terrain T/A KO's
Old 10-05-2005, 08:29 AM
djd99's Avatar
Also I forgot to mention the red spark is on all four so im assuming the coil packs are good.
Old 10-05-2005, 08:33 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Help Electrical/Ignition problem
Sounds like the crank position sensor has gone bad. Sometimes the cam position sensor will throw a code but the crank sensor is bad. Change it out and you should cure the problem. If for some reason it doesn't the ignition module may be bad but the CPS is much cheaper to replace so do that first.
Old 10-05-2005, 03:54 PM
maxwedge maxwedge is offline
A990 racer
If youn scan it and see no cranking rpms, then suspect ICM or crank sensor, there is a diagnostic test for both of these in a good scanner or shop manual, using a digital ohmeter, reduces guess work.
Old 10-06-2005, 08:05 PM
djd99's Avatar
Thanks for such a quick reply I pick up a cps tonight after work and will be throwing it in tomorro. I'll keep you informed Don
Old 10-07-2005, 06:21 PM
dizel326 dizel326 is offline
does your car's lights (headlamps & gauge) flicker on and off. I need to know because my car does the same thing as yours does plus this & autozone told me it could be the crank shaft sensor.
Old 10-11-2005, 08:29 AM
djd99's Avatar
Yes it does I did however replace the crankshaft position sensor and it still does the same thing.
Old 10-15-2005, 12:01 PM
since you have a red spark you should check your computer module cause your controll module is responsible for your spark output (assuming your spark plugs and wires are ok) guaranteed it should be the problem. to make sure 100% take it off and bring it down to auto zone they test them for free,so does advance auto parts if available in your area Keep updates posted
Old 10-18-2005, 07:53 AM
djd99's Avatar
Thank you to Everyone for all the great advice. However it's possible I may have a couple of problems with this engine. I pulled the valve cover and not 1 valve was moving so I investegated a little further and found a broken timing chain and the tensioner was also broken. I bought a new timing set with gears and a new tensioner and I'm now in the process of replacing this. I will let you all no how this turns out, is there anything else I should do while I have the whole front of the engine apart?
Old 10-19-2005, 01:50 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
yes put in a sport camshaft if you got the room to slip it in. makes for a nice power gain. and since you got the valve covers off, go for ratio rockers as well. you wont regret the added power and performance, unless you are more interested in it being a daily driver/gas sipper.
