Old 10-05-2005, 06:36 AM
tahawus84 tahawus84 is offline
Gear Ratio
If I change my curremt rear end to one of a different ratio will my 4 wheel drive still work right?
Old 10-05-2005, 12:44 PM
Schurkey Schurkey is offline
Re: Gear Ratio
First, you will have to change the ratio up front to match the ratio in back. I have heard--but not confirmed--that about 3% difference in wheel speed is about all the 4wd stuff can take.
Second, you'll have to screw with the computer to get it to accept the new ratio so that it knows what speed you're going. Otherwise, I suspect you'll have no end of trans shifting problems, drivability problems, etc.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 10-05-2005, 10:33 PM
dach95 dach95 is offline
Re: Re: Gear Ratio
I wonder if that is why my 4WD locks up easily... I don't use 4WD unless it snows.
2002 Chevy TrailBlazer 4X4 LTZ EXT Summit White
4.2L I6, 3.73 rear diff ratio K&N HighFlow KN-1009 air filter Airaid Throttle Body Spacer Sylvania Silverstar Lows 9006ST
Infinity Burl Wood molded dash kit In-Channel VentShades 35% front windows.
Excellent source of info http://www.trailvoy.com
Old 10-06-2005, 06:57 AM
Whem I bought my trailblazer I needed to swap in a whole new rear axle ass. because the previous one was broken. I think the one I put in is a different ratio than the front one. My 4wd locks up also on dry pavement if i go over maybe 5 mph. I also also have the speedometer problem , it is off by about 5 mph. Car drives fine otherwise. I have been looking for a rear to match the front but cant find one. Any one know where I can find one?
Old 10-06-2005, 10:23 PM
ScarabEpic22 ScarabEpic22 is offline
Re: Gear Ratio
Look inside your glovebox for the RPO codes. There are 3 options for TBs, 3.42, 3.73, 4.10. If it says GU6 you have a 3.42 ratio, GT4=3.73, or GT5=4.10 ratio. Also, if you see a G80, it previously had a locking differential. Hopefully you can figure out which rear axle your TB originally had and get a new one with the proper ratio! Good luck!
-Erik
2002 Chevrolet TrailBlazer LT 4X4 -Summit White w/Oak interior
Many Mods, latest: EFILive tuned by (me)
Old 10-06-2005, 11:03 PM
Re: Gear Ratio
Can I find out the ratio from the vin number also?
Old 10-07-2005, 06:14 PM
Re: Gear Ratio
Dont think so, unless you want to hassle with going to a GM dealership and asking them to run a specs sheet on your TB. It is much easier to just open the glovebox up and look at the first or second row of letters/numbers. They will be in groups. It took me only about 30 sec to find the GT4 and G80 codes on my TB.
-Erik
Old 10-08-2005, 11:23 PM
The reason I ask is I dont have the trailblazer I swaped the rear out of anymore but I know the vin. Ill just have to ask the dealer, I doubt they will be excited to help.
Old 10-09-2005, 02:11 AM
Re: Gear Ratio
Ohhh, thats the reason for the vin question. Sorry, cant help there.
-Erik
Old 10-17-2005, 04:36 PM
Re: Gear Ratio
Ok I found out what I gearing I need. Do I need to order anything else other than the ring and pinon?
Old 01-31-2006, 01:32 PM
RootBreaker RootBreaker is offline
Re: Gear Ratio
if you are doing this yourself.... and your asking this... you may need to get someone to do it for you...
usually just a ring and pinion is needed... if there are alot of miles... get the installer kit too.. usually replaces bearings, races, and shims...
randys ring and pinion is a good source.... google it... for their site
