Old 10-04-2005, 10:47 PM
kimonagro kimonagro is offline
ok fella's here's a new one for you all.
Before i start i just wanna thank all you guys the responded to my previous posts it was reall appreciated.Ok the new problem is my A/C but im thinking more along the lines of the fan, the A/C compressor is cycling and the clutch is kicking in but the cool air i usually get isnt coming through, when i turn the heat on same problem it is not blowing heat out, when i put it on fresh air and drive the air from outside seems to be pushing the heat or cool air through but only just.I checked the fuses under the dash and cant see nothing anyone got any idea's.
thanks in advance
Old 10-04-2005, 11:25 PM
OverBoardProject OverBoardProject is offline
Banned
Re: ok fella's here's a new one for you all.
The motors do burn out but usually with warning (being a very high piched squeel)
I would say check the wiring under the hood right by the motor. I've seen this wire become disconected several times before for some reason.
Good Luck, I hope that's your problem
Old 10-05-2005, 07:26 PM
Re: Re: ok fella's here's a new one for you all.
thanks OverBoardProject you were right on the money the wire became disconnected from the under side plugged her in and she is working fine
Old 10-05-2005, 07:31 PM
Bads Crew's Avatar
Bads Crew Bads Crew is offline
Re: Re: Re: ok fella's here's a new one for you all.
GOOD CALL OverBoard!!
Old 10-05-2005, 08:15 PM
Banned
cool! Glad to hear that!
I've never figured out why they become disconected, and for some reason I've only seen it happen on Chevys
Good design though and an easy fix
