Old 10-04-2005, 10:27 PM
grady61 grady61 is offline
strange problem after t-belt replacement
Had the timing belt, tensioner, and water pump replace on my sons civic today at a repair shop. Now I dont know if this is coincidence but, the car sometimes does not start immediately have to try a few times as before it started right up. Its cranking fine just doesnt start almost like theres some sorta lil funky timing problem. It doesnt happen everytime. Any ideas what they might have done or not done to cause this. Also the car is a 91 civic wagon with the 1.5 liter.
Old 10-05-2005, 04:49 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: strange problem after t-belt replacement
all grounds are where they are supposed to be at? you say it does not start sometimes.....................is that with a crank or no cranking?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-05-2005, 06:15 AM
Hybrid1990crx's Avatar
is the timing right? does it drive the same as it did before the timing belt job? any lack of power?
Old 10-05-2005, 10:31 AM
4thgenSIR 4thgenSIR is offline
Sometimes the pgi fm relays go at strange times. If it is cranking without fuel or spark and then starting up all of the sudden it may be worth a try. When mine went I noticed that when I banged under the driver side dash, the car would almost start. changed the relay and it fired right up.
Old 10-09-2005, 04:44 PM
It only happens every now and then and yes the car is cranking. Like I said this never happened until the timing belt, tenisioner and water pump was changed. Wondering if the mechanic knocked something loose or something. The car runs great its just this little glitch. Is there some sort of adjustment that could have been screwed up that would maybe cause this?
Old 10-09-2005, 09:20 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
I agree with Hybrid1990crx, I'd check the timing.
If the timing belt was not installed correctly the timing will be off.
Also check to make sure the rotor screw is tight, just in case.
Also does this hard start condition happen after the car has sat over night?
Perhaps the main relay is becoming dodgey?
Old 10-10-2005, 06:26 AM
hmm if you say that it still feels the same once its running then im thinking its not the timing. check the cap on your plugs, make sure your injectors are firing correctly and test your main relay with a dmm.
Old 10-10-2005, 11:57 PM
OK this is what my son is telling me if it doesnt start right up, anytime it has happened, is when he turns car off for a short time(maybe 5 or 10 minutes or less) then tries to start it. Its been sitting say for an hr or overnight,not sure of exact amount of time, it starts right up. every time
Old 10-11-2005, 11:16 AM
ok sounds like a main relay then.
Old 10-12-2005, 08:33 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
main relay for sure..you have to go to honda to get them, unless someone here has had luck from someone else
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
